the other plugs are blue lolWhat were they thinking with the green plug things on the mounting bracket though.
it does pull heat away from the radiator and exhaust it out of the case.that's a nifty little LianLi fan. It's hooked up to the front bays adjacent to the mobo i'm guessing, right? and not the lower PSU section.
Also, one more thing, the fan/radiator with the Khuler, does that actually extract air from the case as well or does it purely just radiate heat out from the water cooler? If it exhaust's from the whole of the case, I'm assuming you have a push pull air flow system running right?
Sorry for all the Q's, just want some tips for when I build a new rig and get either this or the h-50/h-70.
Umm... why aren't the images showing? Typical![]()
Nice rig Shayper, how's it working out for you? You've got 6950 in crossfire as well so I'm presuming you generate quite a bit of heat as well right?
What's your push pull system like? You and Schizo have got a couple of pricey cases so I guess airflow shouldn't be too much of a problem. I'm thinking of getting the Zalman Z9 as that's going to be more in my price range.
And yeah there's quite a bit of heat in my case, but it's bloody freezing here in London!
