That's the unsorted bookmarks button isn't it? I think that's static where it is unless you drag the bookmark toobar in customise view to far right so it pins right instead.
How do you only show icons for the bookmarks tool bar?
...and get a separator in-between them all?
Which extensions in particular? I have 28~ and all of them were updated by the first few RCs.
liking FF4, but wish they made it as quick as chrome.
not my results but take from sr ware forums
benchies uses:
http://clients.futuremark.com/peacekeeper/index.action
http://www.webkit.org/perf/sunspider/sunspider.html
Is there away to fix to the annoying wiggly/blurry text issue?
Thanks.![]()
