- 17 Dec 2004
- Crawley, WEST SUSSEX
£100 cashback from TCB.
OK it must be me being tired but what is TCB? And where are u getting a £100 cashback?
khan: you gone back to launcherPro or you still prefer GO? what you use for the lock screen? isn't the currently discharging a waste of space as you should know that? also the good heatlh one as it's unlikely to be in bad health for ages noW or is there a benefit to knowing it? from what i can see it looks like you've managed to get the bat percentage in the notification bar. if so how'd you manage it?
In case anyone wanted the O2 stock firmware > http://www.multiupload.com/VHX20NJEAP
Khaaan! - smooth pics
is it possible to log into 2 android phones on the same account at the same time?
Where did you get this from?
I downloaded it from Samsungs FUS server (Kies) and decrypted it.
Yes indeedy!Will this put back the O2 branding and unrooted then?
Yes indeedy!
I bought a PAYG phone from my local store, it was unlocked and had no CSC?
I'm not sure if I need to set one or why I didnt have one in the 1st place?
Well you 'can' use it with no CSC, you may find some services looking for settings and it generally acting up. Personally I would set one, XEU.
CSC = Customer Specification Configuration.
The CSC defines all the default bits (default language, time format, emergency numbers) network APNs and branding if there is any.
To set the CSC type *#272*imei# (your imei), this will show you the CSCs available. If you select one it WILL factory reset the phone.
