- 19 Oct 2002
- Torbay, Devon, UK
alexhull24 are you by any chance on a business contract. (my boss is and thats what they offer him).
Wow, this thread has died a bit of a death!
Is anyone using CM7 on the SGS now?
Well I'm currently deciding between CM7 or MIUI because I simply fancy a change.
Not all custom ROMs have problems, or they have the same problems as stock ROMs tbh. I've been running Doc's ROM JS8 for quite a while now and it's flawless and no need for lagfix, but I've just got the itch to mess about!
Ive tried most and there is always something.
Well if you get the urge to try something new, go to the ROM kitchen and cook up a tasty DocRom. The JS8 base I've been using (with JPY modem) is solid and fast.
EDIT: I'm just about to try CM7 for ***** and giggles.
Tried and it wasnt satisfying
I didnt get on well with CM7
Best i have had is a stock ROM WJS8 and speed mod kernel with all Samsung bloat removed. Even then it wasnt 100% stable enough.
To be honest brummie, its more likely to be a hardware fault on your handset, an app you are installing or restoring (with data?) or user error (bad flash, not clearing cache etc), doc's kitchen JS8 roms are long past proven stable (not inc roms from the Beta, which may still have some issues under Gingerbread).
I regularly read XDA and follow the kitchen, not seen any JS8 complaints other than user error.
this is not meant as an insult or attack on you, I know just how fiddly flashing can be, but stick with it, cook a rom with minimal apps, flash it with a WIPE rom, don't install anything untill you test the base is working, then start adding your apps or restoring them, but Not the Data....
Could you be more specific? I don't get on well with my uncle, doesn't mean he has bad battery life!![]()
You should concentrate more on being friends with your Uncle than flashing your phone.
