Replaced the handset in store as I'd had it under 2 days...and this one is just as bad...Sat next to my wife San Francisco which shows Good Signal Strength and 54Mbps and SGS2 shows Poor Signal 13Mbps.
BALLSSS
Hey you guys that are rooting and removing stock apps etc, how are you backing them up before removing them? I'm guessing once removed things like the social hub are gone forever?
Also, secondly, I see on the XDA forum that there's 2 different types of firmware, generic and stock, what's the difference?
BALLSSS
Strange I can stand a good distance from mine at the other end of the garden and still use the net, walked down the road a good 100 meters and I was still able to surf via wifi.
Think mine is working alright...
Download: 14313 kbps
Upload: 5234kbps
Tried resetting your router?![]()
assume I should be getting more than this over wi-fi then?
(phone is less than a metre from the router)
I've got setCPU and and I thought that setting lower frequencies would be better for battery life? The sliders let me choose between 200 and 1200 Mhz (200>500>800>1000>1200) I have my min set at 200 and max to 500 during casual use like txting and browsing internet. tbh not sure if it has made a difference to battery life.
What speed do yo get out of a desktop? I get 3600 down and 1200 up from desktop, 2100 down 1000 up with phone next to the router and 1200 500 4 meters away...
Something isn't right with my combo...
Edit: just FYI iPad get 3450 and 1100
What router you using?
200mhz is definitely too low...
Maybe im not been clear enough wi-fi and mobile connection both give you internet connection right?
Well there are times when i do not wish to be connected to the internet by doing this by turning off data packet then you will not receive any MMS messages, forget about wi-fi if you will.
200mhz is definitely too low... I had it set to drop to that when the screen off and it owuldn't let the device wake up... not good. Now set it to 800mhz to test and it seems fine.
Battery now at 50% after 9.5 hours, WiFi on all the time, GPS on half the time, tons of playing around with it.
I tested GPS earlier with Google Nav and it locked in 2 secs once exposed to open sky, never seen the like of it before.
Really, really impressed.
Any news on NFC version for UK.
Correct worth knowing if you travel abroadMMS is classed as data, so you'd need mobile internet on to retrieve it. There's no way around that really.
I never really thought of it like that, that your phone will be live to internet all the time.Gotta say I am seriously impressed with the audio chip in this phone,watching some mkv TV series I transferred over and the sound quality is superb.I'd go as far as to say its what I'd expect from an amplified source.
Via headphones of course.
