Just started watching the forum. Is it me or is EJ drunk?![]()
Where do you think he'll go? It's not going to be Red Bull or Ferrari, that's for sure.
If the FIA do ban the EBD by silverstone, I think it will be a game changer, JMO mind, the whole mystical Adrian Newey thing and the flexi wing all depends on the EBD,
IMO RB can run the car at a steeper rake because of the extreme use of the EBD, the front wing then runs closer to the ground for geometrical reasons, the aerodynamic load on the front wing probably increases with the inverse of ride height squared and hence the wing flexes and runs even closer to the ground.
The effect of the rake at the rear of the car is to create a larger volume defuser, normally this would stall due to insufficient air flow, however the addition of the engine exhaust flow at low torque demand, gives sufficient flow for the defuser to work. When going full throttle along a straight, the defuser stalls again and hence has low drag.
Basically the RB aero package collapses with no EBD. I reckon RB will struggle to get podiums if they do ban the EBD.
Maybe they have set silverstone as a date to ban the mapping so that teams can sort out a plan B.
Thats the thing, I really have no idea, but it just seems to be getting more and more likely that he will end up *somewhere* else. That or he is going to walk from F1.
Yes but will the season be done and dusted by then? thats the real question, will this ban come into force too late to make any real difference to the season.
I thought his interview was awesome and spot on. The other drivers, they ARE idiots. And I'm like his biggest fan.
Hamilton appears to have turned to the dark side. It's a totally viable way of life![]()
'That Trick' sldsmkd is purely them running **** loads of fuel through that exhaust system to get the defuser working very very well.
Someone feel free to correct me!
