Anyone care to share the beta firmware for iphone 4 / 3GS + iTunes 10.5?
y u no Google?
Also, you better have your UDID registered otherwise you'll be looking at a shiny brick.
Noticed a couple of bits.... I like that it now shows how much space is being used by each app within Settings > General > Usage
Also like how you can choose what type of notification is shown for each app. So you can set the classic modal type popups for certain things (say, SMS) and have the new style notification for something else, or turn them off all together. Can also choose what appears in the lock screen etc (and yes, thank god you can turn off the pointless stock ticker).
New grid overlay option for the camera (at least I think its new?)
iPod app is now pointlessly split into 2 'apps', Videos and Music.
The new 'purchased' menu within the App Store is brilliant. Well overdue!!
(Bug) Swiping down from the status bar to show the notification pane also causes whatever you were viewing beneath to scroll up to the very top just like when you tap the status bar on iOS 4 or lower
(Bug) Trying to change wallpaper doesn't work for me first time. Takes 2 or 3 goes then makes the device run slow for a minute or two
One thing I read is that you can create albums directly from the camera roll (aka photo albums+ from cydia) - can anyone confirm this?
Confirmed.
There's a big Android update out in a few months, I wonder how iOS 5 will look then. As at the moment Apple have just copied Android and jailbroken apps with a bare minimum of originality.
Of course the general public that think iPhone is the be and end all will think everything is original and exciting.
SureAny chance of a few screen grabs of the popup/notification settings? Interested in seeing the layout....email in trust if you'd prefer.
Trololololol
So I've had a friend tell me that they are running the Beta on their iphone 4 and that there are widgets in it? Can someone confirm if there are widgets (like on Android) in this??
