- 28 Jun 2006
- Newcastle upon Tyne
That's what I'm trying now. I've removed a handful of apps (the ones I use least) and I'm monitoring the data usage. So far today it's been ok, but these problems seem to occur around midday. My only issue with this particlar method is the fact that I can only run so many unsuccesful tests before I get stuffed by my providerSounds like your probably going to have to do it the hard way and either unistall all the apps you have downloaded or do a factory reset and see if it does it then. If it does then its one of the standard apps doing it, if its fine then you'll have to install your apps one at a time to see whats using all that data.
