I assumed it was just flash not the whole camera...Ok, is it fair to say this this is stuff that we really shouldn't have to mod. I needed to take some important pics today and I couldn't, I can understand that the LED flash would be disabled on low battery but the actual camera is a joke.
What about using a third party app for taking photos camera 360 for example?
I don't get why people are giving off about certain things not working the way they should or the way that they would like it to and then when someone suggests using a third party app, you get an answer you shouldn't have to with a £500 mobile, which I agree with in some ways but it is android, the whole purpose is choice and customization and every android mobile isn't perfect out of the box.
I have been noticing this in the last few pages of this thread, people posting problems, which are easily fixable by just simply installing an app e.g. widget locker and using resources, you have 1GB of RAM after all, which is more than enough, iirc widget locker only uses 14-16MB of RAM and will hardly impact performance of the mobile. Plus, it doesn't take that long to customize and set it up. And if you can afford a £500 mobile, you should be able to buy an app for a couple of pounds
If you want something out of the box that just works without having to do anything with third party apps, then the iphone 4 is the one to get, however if you want a powerful dual core then the HTC sensation would the next choice, although even the iphone 4 and the sensation will have some problems out of the box.
Out of curiosity, how in your mind could a pin-locker be better?
I have a pin on my GS2 and i can't see any way it could be better.
Please don't take it personally, I like customizing stuff, just not to fix simple functions that really shouldn't be broken in the first place. I have been customizing phones for a long time, just not android. I am using launcher pro for example on my GS2. Yes I know there are always gonna be custom apps which claim to be better etc and that is fair enough if they do.
Just one point is the lockscreen which is again total pants on the GS2. I like to have a pin lock at all times and find the pin lock screen is just a bit poo. So I tried wigetlocker after good reviews and initially thought great this is better, looks great, good customization, until I realised it doesn't include a pin lock. unless you use the standard one as well as widget locker and then that just defeats the object.
And its little things like this thats just getting on my nervs. I don't mean to moan. Just hoping for solutions that maybe I have overlooked.
Lol, don't worry, I am not taking it personally
And that post wasn't just aimed at you, but to other people as well.
Unless you need LPP for the widgets, try go launcher out
Ah, right fair enough if you need the security lock on, maybe there are some other lockscreens out there that provide that, GOTO lockscreen and lock bot are other alternatives to widget locker, although I do not know if they have any security lock at all.
What about using the pattern lock instead? Which I think is pretty decent.
30.64 month 18 month
phone £19.99
600 minutes
500 texts
unlimited internet
t-mobile
From Mobilephonesdirect I'm guessing? Was scared to use them due to reviews.
Don't be, they are pretty good.
Every single shop website on the internet has bad reviews, people don't tend to bother posting good ones.
