Man of Honour
- 21 Nov 2004
Finished what I can with my mine to hell. Need a nightmare pickaxe next - best way to go about getting this? Head to corruption?
Not sure of how to progress, gold is apparantly the best you can make for the basic stuff. Any suggestions?
Yes
No - but you'll spawn at the same point in that map every time (usually right in the middle, horizontally). Create a safe house (with a bed) means you can spawn closer to your favourite mining area, etc.
There's a spawn point in each world. Worlds aren't linked in any way AFAIK.
Noooooo, My house! I have spent most of the 42 hours playing this game doing that.![]()
Summon the eye of Cthulhu to get demonite ore. Go to the corruption to destroy orbs to summon the eater of worlds. He will drop demonite ore, shadow scales and one piece of nightmare armour.
Make sure to take purification powder and dynamite to access the orbs.
Aye, he starts spawning by himself when you character has 10 health pips and 10 defence or higher, and you haven't already killed him.Will he spawn again randomly?
Has anyone else noticed that when you spawn in your house, you destroy 3 of the wooden floor pieces when you "pop"?
Happens to me every time. Will this stop if I change the structure to stone?
Getting addicted to this quite easily now.
Bought a copy for me and the wife, and last night I ran the world I'd created as a server which she was able to join easily. After playing around for an hour or so, she left and I quit the game but didn't see the same "saving world" notification that I do when quitting single player. Will it stay persistent with the changes we've made when running as a server?
If I leave things in the chest at our house when running as a server, then launch the same World in single player, will my chest-stored items still be there?
The spawn problem is likely because you have not created a bed in your home, so you are spawning at the original spawn point. The game forces you to spawn exactly where you first started in the game, and your house sounds like it's in the way slightly. If you build a bed and put it in your house, right click it, and when you die, or log on, you will spawn at the bed. That should stop the blocks getting destroyed.
When playing on a server, I believe that the game will save changes as they happen, and they will effect the map both in single player and in multiplayer.
If you leave items in a chest in a multiplayer server, they should also be in the same chest if you play the map in single player. If you take the item out in single player, then the item should also have gone from the multiplayer server.
Hope that helps.
Edit: If you want to create a bed, then I believe all that you need is wood, silk (created from cobwebs), and a workbench. Right clicking the bed will set it as your new spawn point. You will get a yellow message in the bottom left area of your screen if it has set correctly.![]()
just found my first regen ring!![]()
