My god it wasnt a lie all of this time!
I could sell you my x2 550, unlocks to 4 cores fully & runs at 3.8ghz quite easily.(was using a crappy £40 odd motherboard.) Email in trust if you're interested.
btw you can use your pci-e 1x card in the 4x slot if you can't use the 1x one
yeah it'll just run at 1x speeds![]()
, not that its even worth testing that x-fi though ? :LSo wheres the £600 been spent then?
I see a old stacker, someone was selling an identical one in the MM for a few bucks.
A 8 series motherboard worth about £60 new.
A really old sound card worth £5 second hand.
And a £100 ATI 5830.
I got a 5850 brand new for cheaper![]()
seriously cleeecooo why aren't you having green in your new build?![]()
looks quite good actually
I like the green![]()
well it is a build log
reverse atx cases do look good, and since your psu is currently at the top, you have the added benefit of having the psu at the bottom
just get your pc up and running first though![]()
your a top man for the pictures zacc, cheers, and dont get too into the modding thought as your main focus should be getting the cpu or money back from ebay and getting a working PC,
well at least you'll have a working pc tomorrow![]()
