4pm iirc
edit - 4:30
exactly the same, I've done it before![]()
intake, heat rises.
i would do it like this.
front=intake
rear=exhaust
bottom=intake
side=exhaust/intake (doubt youll have enough fans)
top=exhaust.
how many fans do you have and how many can your case accommodate.
intake, heat rises.
front=intake
rear=exhaust
bottom=intake
top=exhaust.
I may be, is it prime stable @3.8ghz, and what sort of cooling where you using?
Mine was prime stable at 4.0ghz on a titan fenrir evo, just for reference.
I have the Akasa Nero S, it looks far smaller then it is, and is probably around as good as the titan fenrir
Should have bought that chip imo, probs cheaper and better. -_-
Alas, after 6 months of waiting on a cpu my mother wouldnt let me buy of a unreliable source this time :L
But hey, go for it. and what the hell is that orange fan doing, take it off immediately.
Little late anyway, i had gone for it at like 2.30pm :L and yes im going to take that fan of :L
EDIT: See this word next to this writing. its an edit, try doing it for some of your posts. might work out better for you, and the thread.
i do know how to edit posts, it was a duplicate post, but i thought i was in edit :L
(hopefully)okay, well my cpu hasnt arrived yet, but im doing last moment preps such as dowloading raid drivers, putting my ram in the blue slots (better for ocinc) putting my 5830 in the x16 slot, and so fourth,, just killing time before i get that knock on the door sometime later(hopefully)
Jokes.
I guess this is the end of a journey when the CPU arrives.![]()
Lets see what benchmark score you can do with that x3 and 5830
