Will the "Thermalright Venomous X Black Edition" cooler fit ok, as the heatsinks look quite high around cpu?
Depends on the ram that you have installed. If it's low profile it should be ok.
What ram and case are you using ?
I ment the 2 heatsinks ubove and to the left of cpu,, I havent bought the memory yet, but I'll be buying some low profile ram, as memory with fins are a bit pointless anyhow.
anyone have the inverted mouse problem in BIOS?
hmm its alovely looking board
Yes but £170 is well over priced.
I've just purchased the Extreme'3' Gen 3.. similar features, but slightly different looks e.g. the heatsinks look better IMHO.
Stop the competitor discussion please.
And just for you guys the price has just been dropped by £15![]()
