Caporegime
- 18 Sep 2009
- Dormanstown.
I'm placing bets on late september or early october
The kind of arrogance, evasion and denials in JF-AMD's post are the exact reason that i as a long term AMD user deserted AMD and went Sandybridge.
What's the point of this thread again?
I mean, if you don't and won't know anything about it
until its launch day, which we don't know either???
native USB 3.0 support & PCI-E 3 support will come in the next socket/chipset change, most likely q1-q2+ 2013...SB950 doesn't give native USB 3.0 support. There's one inaccuracy.
Also, where's the PCI-E 3 support?
most people don't care if it dose/doesn't have native USB 3.0 support.
where it says usb 3.0 in the slide it could be a mistake/typeo just like the ram speed in the slide but when u read the article it states the right speedYou're missing the point.
That chart says SB950 and lists USB 3.0 as a feature of it. Wouldn't that denote native USB 3.0 support? Which it doesn't have.
I'm going to say the chart's fake. Because it's got inaccurate details.
Can't really see what the problem is here. Just wait until it comes out. Some of the posts are just ridiculous, it sounds like some people have a magical crystal ball. Wait until release.... is it good? Yes, then buy one. Is it bad? Yes, then go Intel. Wow tough concept for some to grasp. Don't really see why some people are getting upset by this.![]()
And some of the people making the most noise have already made their choice with going SB already, so either they want BD to fall short or they are angry that AMD did not have it out sooner if its better and due to not having the patiences of waiting ended up going SB.
Either way the suspense is killing them.
I think people just want something interesting to happen.
We thrive on competition.
Yes but i see no point at all in getting worked up over it.
if your meaning virgo it does show USB 3x4 supportEven if it wasn't. It shows the new socket FM2, without PCI-E 3 and USB 3 support. Which isn't realistic.
. But it states SB950 has native support, so it's frugal.how.... we don't know if amd are just going to update the sb950 chipset to have native USB 3.0 supportI missed that, my bad, I was on a roll. But it states SB950 has native support, so it's frugal.
how.... we don't know if amd are just goes to update the sb950 chipset
