Don
- 20 Oct 2002
- In a house
My China case for 10quid from ebay is pretty cool
Have you enabled Developer Mode?
Was that fixes for the crack?
Anything different? Wondering if they are just replacing with the same case or a new improved one to stop the cracks from forming.... Mine will crack I bet but hasn't just yet.....
well mine came back today all repaired with a new casetime to get the hacks back on it!!
I've done everything by the book. I think the problem lies with the Navacom service which won't start, which is probably down to a conflict with s/w on my machine. Next I'll try on a fresh build with nothing loaded and see how I get on.
Thanks for all your suggestions.
Wish i got a 32gb version now even though the 16gb was cheaper and has a brighter screen, just incase windows 8 gets working on the touchpad next year.
Does anyone know how to switch Facebook accounts? I managed to switch to my girlfriends but now I can't switch back. In the accounts preferences it says the first account will be used but I've changed my account name to 'A' and it still doesn't change.
AFAIK no one has mentioned running Windows 8 on the Touchpad, and I wouldn't think it likely. And 16GB or 32GB wouldn't seems to matter that much even if it was running.
64gb might make a difference
I just want HP to release the other accessories such as the hdmi usb dongle.
I should be getting my 16gb bundle today, woo!
I've had a quick look at the guide on the first page. Is there a way to set it back to factory defaults should I need to? I couldn't see anything about that.
Thank you very much for that.
Also, does overclocking the processor to 1.5ghz actually make any noticable difference?
