So i'm stuck, the M4 i have installed works great and i have no problems. But it's on 0002 and my Bios only have options for ACHI or RAID. Is there a work around?
PS - i get 7.4 on mine as well.
The Marvell SATA3 controller is pretty poor and you wont get the full speed out of the drives with that.
http://www.overclockers.co.uk/showproduct.php?prodid=CC-004-SR
A separate SATA3 card will help
(the pci-e card that is)Ouch didnt notice it had a marvell controller(the pci-e card that is)
Turns out I hadn't set Marvel interface to AHCI, now I have close to 400mb/s.
Quite happy with that TBH.
It'll work, just not at full speed.
What kind of speed would I be looking at? Will I still notice a big difference over my normal HDD?
