thanks derp I used this to do it...
http://www.storagereview.com/how_upgrade_crucial_ssd_firmware
http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
even easier to create the drive. worked great and now get 508 MB/S instead of 415![]()
Recieved the drive today, installed it and immediately updated to 0009 (via a USB stick, very easy to do) and did a clean install of Windows. Updated directly to latest Intel chipset and Intel Storage drivers. Does this look any good? Some of it is okay but other results (4K) look a bit low imo. This is on a SATA II interface on my HM55 laptop.
heres mine with a mostly full drive.
after - 22s boot time
I was able to tweak the RAID setup of the 2 x 64GB M4's and was able to squeeze out some better numbers than I got before.
System:
- i2500k CPU running at 4.2Ghz overclocked (stock volts)
- 2 x 64GB Crucial M4 SSD's running firmware 0009
- 8GB Kingston PC10666 DDR3 Ram (HyperX Blu)
- Gigabyte SoC GTX460 1GB Graphics Card
- MSI P67-G45 B3 Motherboard running latest beta bios.
- Antex TX650W Power Supply
- Antec 300 Case
Why are the seq write times so slow?
my spinpoints seq's are faster than that
With trim, how long before performance on these drives starts to degrade? Seems a bit of a major negative for SSD's if you ask me. What do you need to do to restore performance? A reinstall of windows?
With TRIM performance won't degrade, that's the whole point of TRIM.
I know TRIM is supposed to reduce degredation. But I didn't think it stopped it altogether?
It's really easy. Well the way I did it is MUCH easier than the tutorials online
Open up the M4 0009 Firmware update ISO in 7-Zip, go into the BOOT\ISOLINUX folder and extract the BOOT2880.IMG file.
Download UNetbootin and load it up. Choose your USB flash drive, click the Diskimage radio button and from the dropdown box next to it choose floppy.
Use the ... button to browse for files and choose the BOOT2880.IMG file that you extracted.
Hit OK. The files will be copied to your memory stick. Reboot the PC with the memory stick in and make sure you turn AHCI off in the BIOS and flash the new firmware.
Job done!![]()
