Hold down on the desktop and choose widget, should be in the list.
Yeah cheers. Just noticed that
Should be very similar procedure to the S2 mate. Use Odin to flash a generic firmware (JVT will do just fine) and you should be good to go. Just make sure you backup everything first. I also factory reset and format internal sd just to make sure things go smoothly. Also, with the Galaxy S you may need to repartition the phone when you flash with Odin. Use a 512 pit file. It's all there on XDA.
My girlfriend has just got a new SGS2 so she's given me her old SGS. It's running everything at stock and has never been updated in any fashion since she bought it. Is it worth updating the firmware etc on it? and how do I go about doing this?
I've no clue what ROMS are or anything like that, I'm pretty much a noob when it comes to mobile phones.
Cheers
Ok cheers, I take it that I need the mini USB cable to do this?
The plastics on the front/back and also the outer rim is slightly scratched and there's also a small scratch on the screen. I'm wondering is it possible to get these replaced? and for what cost and where?
What's the quickest rom with the best battery life?
First off, I want to back up my contacts, which I've done via Kies.
