- 31 Aug 2009
- Surrey, UK
Great, thanks. I've found the the ASRockAXTU utility is quite tricky to work with. I'm not sure what the target levels/temp settings are for the fans, but whatever I set them at, they're always forgotten after a reboot. Does the utility have to be running all the time? Also will the utility override the fan settings in the BIOS?
The ASUS CPU fan control software was perfect. Like MSI Afterburner for GPUs, you could set the curve for different speeds at different temps manually; AXTU seems quite the opposite.
, to finally replace the stock cooler. Just wondering what the lowest stable VCore people have managed to get at 4.6 on a 2500k? Or has everyone stuck to the Auto OC?
