I was wondering why I wasn't having much luck finding new quests to do, until I looked at my stats:
How many quests are there?
Blimey, you've done almost exactly twice as many as me, and I've done 279 hours so far.
Blimey, you've done almost exactly twice as many as me, and I've done 279 hours so far.![]()
The one thing that I hate about Lydia is that damn "I am sworn to carry your burdens". Its the exact same thing every time in the same dreary voice and it really gets annoying.
-snip-
Isn't it a little tedious trying to use all the skills you don't normally just to max out the levels?
Is it normal for dragons just to ignore you?
Like when they circle over arriving for an attack etc. they just keep flying then after about 5 mins bugger off...
Yeah, I have had that happen loads of times.
I got bored last night so I gave the Greybeards arrows to their knees...
Is there an easy way to manage the game saves better?
Basically I want to create a new character that uses a completely different style, and don't want to get the saves confused.
