Can anyone explain what AHCI mode is, and why people use IDE to update? Completely clueless as I'm setting mine up in the next few days. Do I need it on a USB to update the FW, and can I do this before W7 install? Thanks.![]()
7.8.
I think that's because I'm still on sata 2.
Tried updating my firmware via USB and it hangs on Finding Drives... Anyone else get that or know how to fix it?
I tried IDE and AHCI.
Think I read someone with a similar problem on the Crucial forums got it to work by disabling any third party storage controllers on the board whilst running the update.
AHCI is a newer way of accessing hard drives which gives higher performance, the reason some people are switching to IDE to flash their drive is because the older firmware flasher didn't support AHCI mode, the new one does and there is no issue updating in AHCI mode.
You can update off a USB drive or off a CD/DVD there's no difference, just not everyone has an optical drive these days.
I did mine in IDE mode,was set as RAID before since using M4 64GB as SSD cache drive on my Z68 board, anyway no issues updating firmware via IDE,as you can see typing this post on same PC.
Yes I set my PC back to RAID after.
IDE and ACHI both work, RAID doesn't as far as I know.
I had to switch my marvell controller to ide mode to get the firmware flash to work. It just hung at finding drives before i did this. Note: my M4 is on the intel controller.
Do you have anything connected to the Marvell? Might as well disable it. Shortens POST a bit during boot too.
I did disable it until i realised i had my optical drive on there and needed it to flash the firmware![]()
