I know what over training is, i was saying it's BS you will be over training. Put it this way most upper body workouts since i started i struggle to lift my arms afterwards. If that was a bad thing i wouldn't be gaining would i? At least not at the rate i have been. I'm sure most other people in here will tell you that also.
Oh okay, sorry you just said BS so I presume it was to the entire post / theory
The issues with my shoulder stop me with working my upper body as much as I would like to, for instance I'm almost seeing stars when I'm doing lunges, yet on bench press i'm okay just my shoulder is feeling like it's going to fall off!
Not trying to make any digs buddy, I've seen your progress and it's fantastic
I used to get laughed at. You could hear the plates rattling on the bar
From your posts skillmister you seem really hungry for it. Helps so much! Delvis you give the impression you are very measured and controlled, this is good. But if you turn some of that frustration into controlled aggression it gives you such a boost. Grab the bar and rattle it like a monkey bouncing around a cage.
You have that room to yourself don't you? Shout at yourself if it helps.
Aye I do, sadly there is an office down below...I have however started making Doom 'grunting' noises
They will be shouts soon!
I'm going through a fair whack at the moment, and not feeling myself...Which isn't helping matters, but i'm still enjoying the gym, infact its the one thing I look forwards to currently!
Chest Day:
Bench:
1 x 10 x bar
1 x 4 x 32.5KG
1 x 2 x 40KG
2 x 8 x 47.5KG
1 x 7 x 47.5KG
Had to stop on the last rep, my shoulder was niggling like a booger by this point...It started on the second set.
Inc. DB Bench:
3 x 10 x 7.5KG
Shoulder felt better here.
French Press:
3 x 10 x 17.5KG
These are getting hard now, so next week will be an issue, may need to drop the reps and up the sets?
CGBP:
3 x 10 x 22.5KG
Flys:
3 x 8 x 7.5KG
Not much discomfort on these thankfully.
It appears that my shoulder really has issues with Bench Press, last week it seemed okay, this week it was just knackered...Not sure whether or not I should up the weight to 50KG next week or not. My shoulder has been a bit iffy though all day really.
