Don't try and curl 200kg?![]()
Surely the answer is build up to a 200kg curl! I reckon if you can curl 200kg then your biceps will be fine for deadlifting with mixed grip!
Mate of mine tore his bicep in a similar way, and he was a VERY experienced PLer. It can happen unfortunately (esp as he was a 3xBW deadlifter)
I'm not far off 3xBW![]()
Kind of the opposite, strangely enough. The problem stems from unhealthy internally rotated shoulders, which causes a forward shoulder fault under certain stresses. This increases the tension through the entire anterior shoulder/bicep system, and sometimes the distal (furthest away from torso) tendons give way.Perhaps hyper extending, pulling your shoulders back too far so that it's stretching your bicep with 130+kg being dragged up?
That's my powerlifting club
LOL was just shaking my shake up and the lid exploded off.... nothing like milk and bits of undissolved protein and oats in the face/hair.
Dom, I didn't actually know it was varsity weekend, I look forward to a mediocre performance report...
