PB Squatted 110kg for 6 last night and they where DEEEEEEPpretty happy with that at the moment as in calorie deficiency for some time and sitting at 65kg
That's a really good weight considering how much you weigh. Good work!
Indeed - I've never used just the bar for complexes.
Complexes aren't designed to be used with big weights really.
No, complexes are designed to work on a relative percentage of your 1RM. If your 1RM is 80kg, you're probably safe with 20kg. If your 1RM is 200kg, you'd probably be wanting to use 40 - 50kg.
It's relative to the lifter, not the amount of weight being used. You should use the right amount of weight for your strength so that you're taxing your body sufficiently on each exercise during the routine, otherwise you may as well use a treadmill.
A point of note for anyone interested medicine ball pushups are great for your shoulders. I can really feel all the tiny structures in my shoulders after yesterday.
As in, resting hands on medicine ball and doing push ups?Might be worth me doing these then considering my shoulder issue.
Have you actually seen anyone about that bloody shoulder yet, or you back for that matter.
Well ive had my shoulder issue for two years now I think. Comes and goes
My back I'm getting seen to eventually, some reason every place I've contacted they've not got back to me. So I'm on an NHS queue. In the meantime, I'm working on my core to help with it
Fair enough, if it were something as serious as my back though I'd be on the case of those places every single day, or go and see them in person!
Hope it isn't too bad for you, have had a few twinges in the past, they are bloody annoying.
What? I was told it would give me a 6 pack in 4 weeks?Also I wouldn't go on 531 unless you are pretty happy with how you look, because it isn't going to change how you look by much.
