That's impressive Tommy, I'd be happy losing no strength after 6 months off deadlifts.
Maybe there is still plenty of glute drive there from doing legs, and shaggin'
Maybe there is still plenty of glute drive there from doing legs, and shaggin'![]()
Glute drive is the easy part, getting it off the floor with a flat back only using your legs is the hard part.
Can I be cheeky enough to ask you guys how tall you are and how much you weigh? To get an idea of how much you lift compared to that.
Ah of course, that's helpful, thanks. No heights though![]()
Lots of people have posted their heights in that thread. It makes little odds in terms of what you're able to lift. Of course some heights/body configurations are more predisposed to be better or better suited at some lifts, but unless you're at top elite level, it has little odds.
A shade under 6'1". Currently 92.5kg.
~5'10" and a whooping 60kg of pure muscle.
