booooooooooooom booooooooooooooom paaaaaaaaaaaaaaaaaaaaw in you faces.
150Kg dead ****ing lift x 4 reps.
Not even the French guy here in these forums can beat this!!!
yeah broke the ****ing record
150kg? Is that it? Come back when you can actually lift more than girly weights.
I'll beat you all at pink dumbell kickbacks thoughStop trolling - get out of this thread.
Ok just to make him happy:
150kg x 17
This is an old vid though (2 years?)
Impressive work Syla5, it's good to see people progressing well.
150kg x 17
ImpressiveNext weeks targets are bench 100kg, squat 140kg, and for deads anything over 150, 160 would be nice.
150kg x 17
Do you still bounce the weight FF![]()
I remember that, from the deadlift challenge if I recall.![]()
I remember seeing FF's vid!
We should do another deadlift challenge![]()
On the topic of form. You drive with your legs until straight, then pull the chest back, keeping back as straight as possible throughout?
That vid isn't best form - Dom's latest vid shows excellent form. My vid was part of a deadlift challenge (how many you could do 1.5x bodyweight) - so form was a little bit compromised.
You drive with your legs, then thrust your hips forwards with the gutes to finish.
You HAVE to keep the back straight - no question there. Any rounding, or any lower back rounding then don't bother.![]()
The amount you have bent your knees, is what your doing more partial deadlift or is this as low as is required?
