Post your FTTC line stats & unlocking info
27 Oct 2002
Livingston
Code:
# xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason:	0
Max:	Upstream rate = 30841 Kbps, Downstream rate = 77832 Kbps
Path:	0, Upstream rate = 10000 Kbps, Downstream rate = 39998 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3939)
Medley Phase (Final) Band Plan
       VDSL Port Details       Upstream        Downstream
Attainable Net Data Rate:      30841 kbps         77832 kbps
Actual Aggregate Tx Power:        5.3 dBm          13.4 dBm
  VDSL Band Status        U0      U1      U2      U3      D1      D2      D3
  Line Attenuation(dB):	 3.4	 17.0	 24.6	  N/A	 9.0	 20.8	 32.1
Signal Attenuation(dB):	 8.8	 15.7	 24.0	  N/A	 9.0	 20.8	 32.1
        SNR Margin(dB):	 24.0	 22.6	 22.8	  N/A	 16.9	 17.0	 17.0
         TX Power(dBm):	-9.9	-41.8	 5.2	  N/A	 10.3	 8.3	 6.3
On 40/10 (obviously) and 17a, does the increased speed just give you the most you can achieve up to a maximum of 80/20? BT checker reckons 47.8Mb download and 10.9Mb upload.
6 May 2004
Fareham
More or less yes. Before my upgrade my max attainable stats were generally saying 81000 down and 17000 up. After the upgrade I'm hitting 74826 down and 16877 up so a bit under the previous max attainable rate.
Since your max attainable is saying 77832/30841 it's likely you'll get over 70000 down and the full 20000 up.
14 Apr 2012
@Roboraver Your stats are almost identical to mine @ 750m.
So can I assume that we will never get faster speeds ? (Not that I am complaining for 38 down 9 up !!), I read somewhere about "Vectoring" may improve the speed but I don't know if my line is suffering from Crosstalk ? or how many people are already using it on my Cabinet ?
11 Oct 2007
London, UK
initial, before doing anything other than hacking the router. Should probably also point out that I have been "limited" to 4.8mb upstream for ages, as that is what my asus black diamond router auto reported the rate to be, I manually adjusted it to 10000kbps and it change the pre qos uprate to be 7mb as shown in the second image.
# xdslcmd info --state
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 38290 Kbps, Downstream rate = 92864 Kbps
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 39778 Kbps, Downstream rate = 92652 Kbps
Attainable Net Data Rate: 39778 kbps 92652 kbps
Actual Aggregate Tx Power: 2.8 dBm 12.5 dBm
Line Attenuation(dB): 2.0 9.8 14.3 N/A 6.5 10.9 19.2
Signal Attenuation(dB): 0.7 N/A 13.5 N/A 6.5 10.9 19.2
SNR Margin(dB): 30.5 N/A 30.5 N/A 21.9 21.5 20.6
TX Power(dBm): -13.1 -128.0 2.0 N/A 8.2 8.1 6.7
# xdslcmd info --show
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 38521 Kbps, Downstream rate = 92652 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 21.2 29.5
Attn(dB): 0.0 0.0
Pwr(dBm): 12.5 2.8
VDSL2 framing
Path 0
B: 239 111
M: 1 2
T: 64 50
R: 0 16
S: 0.1909 0.7101
L: 10055 2704
D: 1 1
I: 240 120
N: 240 240
Counters
Path 0
OHF: 149723 51975
OHFErr: 0 0
RS: 0 2598390
RSCorr: 0 0
RSUnCorr: 0 0
Path 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 35286106 0
Data Cells: 906999 0
Drop Cells: 0
Bit Errors: 0 0
ES: 0 0
SES: 0 0
UAS: 19 19
AS: 461
Path 0
INP: 0.00 0.00
PER: 3.05 8.87
delay: 0.00 0.00
OR: 65.46 55.88
Bitswap: 0 9
After disabling QoS
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 38656 Kbps, Downstream rate = 93240 Kbps
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 40442 Kbps, Downstream rate = 96236 Kbps
Attainable Net Data Rate: 40442 kbps 96236 kbps
Actual Aggregate Tx Power: 2.8 dBm 12.6 dBm
Signal Attenuation(dB): 1.1 N/A 13.5 N/A 6.5 10.9 19.2
SNR Margin(dB): 30.6 N/A 30.6 N/A 21.6 22.1 22.9
TX Power(dBm): -13.1 -128.0 2.1 N/A 8.6 8.4 6.1
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 40526 Kbps, Downstream rate = 94524 Kbps
Mode: VDSL2 Annex B
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Down Up
SNR (dB): 21.8 30.6
Attn(dB): 0.0 0.0
Pwr(dBm): 12.6 2.8
VDSL2 framing
Path 0
B: 239 111
M: 1 2
T: 64 50
R: 0 16
S: 0.1909 0.7101
L: 10055 2704
D: 1 1
I: 240 120
N: 240 240
Counters
Path 0
OHF: 50281 17495
OHFErr: 0 0
RS: 0 874664
RSCorr: 0 0
RSUnCorr: 0 0
Path 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 11889827 0
Data Cells: 1203484 0
Drop Cells: 0
Bit Errors: 0 0
ES: 0 0
SES: 0 0
UAS: 16 16
AS: 156
Path 0
INP: 0.00 0.00
PER: 3.05 8.87
delay: 0.00 0.00
OR: 65.46 55.88
Bitswap: 0 7
shouldnt I be getting a higher upstream on the speed tests? That one is the highest I seem to get between the different servers, and BT's gives me 32/7 :(
KIA
KIA
Man of Honour
14 Nov 2004
Vectoring might help. I'm waiting for fibre on demand. :)
4 Aug 2008
Waterlooville
Heres mine after my upgrade couple of weeks ago
Code:
Status: Showtime
Retrain Reason: 2
Max:    Upstream rate = 20031 Kbps, Downstream rate = 67980 Kbps
Path:   0, Upstream rate = 20000 Kbps, Downstream rate = 66288 Kbps
DS: (32,859) (1216,1963) (2792,3959)
Attainable Net Data Rate:      20031 kbps         67980 kbps
Actual Aggregate Tx Power:        6.8 dBm          13.4 dBm
  Line Attenuation(dB):  5.3     29.1    44.0     N/A    14.2    35.4    55.1
Signal Attenuation(dB):  8.5     28.3    43.0     N/A    14.2    35.4    55.1
        SNR Margin(dB):  5.8     5.8     5.8      N/A    6.8     6.6     6.5
         TX Power(dBm): -4.0    -13.6    6.4      N/A    11.2    7.8     4.5
Status: Showtime
Retrain Reason: 2
Max:    Upstream rate = 20024 Kbps, Downstream rate = 67980 Kbps
Mode:                   VDSL2 Annex B
TPS-TC:                 PTM Mode
Trellis:                U:ON /D:ON
18 Oct 2002
Newcastle
Unlocked my modem yesterday after seeing no benefit to the 80/20 upgrade. Wish I'd done it sooner :(
Code:
Status: Showtime
Retrain Reason:	2
Max:	Upstream rate = 6791 Kbps, Downstream rate = 46728 Kbps
Path:	0, Upstream rate = 6902 Kbps, Downstream rate = 39302 Kbps
Attainable Net Data Rate:       6791 kbps         46728 kbps
Actual Aggregate Tx Power:        2.8 dBm          11.2 dBm
  Line Attenuation(dB):	 8.3	 45.3	 65.6	  N/A	 19.6	 55.5	 0.1
Signal Attenuation(dB):	 9.3	 45.1	  N/A	  N/A	 19.6	 55.5	  N/A
        SNR Margin(dB):	 5.8	 5.7	  N/A	  N/A	 6.7	 6.4	  N/A
         TX Power(dBm):	-8.3	 2.5	  N/A	  N/A	 8.5	 7.8	  N/A
Status: Showtime
Retrain Reason:	2
Max:	Upstream rate = 6799 Kbps, Downstream rate = 46844 Kbps
Mode:			VDSL2 Annex B
TPS-TC:			PTM Mode
Trellis:		U:ON /D:ON
Checker estimates around 54/13 :o
Speed tests give 36/6 and real world usage tops out at 4.6MB/s down 800KB/s up.
19 Jun 2009
London
Hi guys, hoping someone can give me some advice.
I upgraded to the free 80/20mb upgrade last Thursday and I was told by BT I could get atleast 74/16. I went ahead with the upgrade and it went through overnight, however it was at 30/5. Previously it was running at 38/8 stable for a very long time so I went through a lot of hassle with them and long story put short they said I have to wait 10 days.
I've reset my router a few times within the past week but still no luck getting the speeds up. I then thought I'd unlock my modem to see my stats:
Now it seems to me I should easily achieve those speeds quoted by BT but just wanted your opinion on the matter come Monday when it'll be 10 days up so I can put a case forward.
Any help would be appreciated
Thanks
19 Jun 2009
London
Nayan89 I also like to know the same, as I have the same problem.
I think what BT have done is capped the line but won't admit it, I'd have appreciated if they did tell me they did for stability purposes or whatever but the fact that they aren't telling me anything until 10 days are up is annoying me :(
19 Jan 2010
South West
What does annoy me is that my contract as been renewed for another 18 months, & I don't get the free speed upgrade.
I'm not pleased:mad::mad:
5 Jan 2007
Smallbrook
Just got upgraded from C&W ADSL2+ LLU to Uno (www.xilo.net) FTTC this morning :)
Code:
Profile 17a
Max:    Upstream rate = 17664 Kbps, Downstream rate = 62836 Kbps
Attainable Net Data Rate:      17664 kbps         62836 kbps
Actual Aggregate Tx Power:        6.7 dBm          12.6 dBm
  Line Attenuation(dB):  4.4     24.5    37.2     N/A    12.5    30.7    48.5
Signal Attenuation(dB):  6.8     23.7    35.8     N/A    12.5    30.7    48.5
        SNR Margin(dB):  11.6    11.5    11.5     N/A    12.9    13.0    13.1
         TX Power(dBm): -3.8    -20.5    6.3      N/A    9.1     8.1     5.9
