I was just looking at RDL and wondered what peoples thoughts were on it. Is it a good alternative to the traditional Deadlift? Does it put much pressure on the lower back, or is it mainly the Hamstrings, Glutes etc.
They're paused squats - so I paused for a second at the bottom, and as I got to the bottom, I... well... kept going down!
<3 Steedie
Wasn't feeling goodTired and weak...
Keep up the good work. How you finding Stronglifts so far?![]()
Big clean!82.5kg powerclean today
Also 75kg hang clean
Also.... A bleeding shin
back up to 22kgx3x10 dumbbells with ease on the bench press! (injured shoulder kayaking)
Shoop de whoop
The only exercise that can really replace the deadlift is the clean.I was just looking at RDL and wondered what peoples thoughts were on it. Is it a good alternative to the traditional Deadlift? Does it put much pressure on the lower back, or is it mainly the Hamstrings, Glutes etc.
Nice work!Wasn't in the mood today - really exhausted
Squats
60x10
100x8
110x5
120x3
130x1
140x1
160x1
170x1
175x1
180x0
165x1
165x1
165x1
165x1
160x1
160x1
Reverse lunge
70x5x5
Isometric bulgarian split squat
70x5x5
Isometric roll outs 7x20s holds
They already exist!rofl, love the description![]()
Hey...It might take off you know? Negative squats....
RDLs are awesome though, and don't put pressure on the lower back if done correctly.
They already exist!
Yeah I might.
I've a friend who has lifted for a long time, who watched me last time and it was all good, but sadly he wasn't there with me today when the weight was higher (getting towards my working weight). Some real time feedback is what I could really do with... The mirror situation will be solved soon I hope... Hopefully I've not ruined my back in the mean time...
Cool, will give them a go too then. The RDL will help me work on my deficit part of the DL because as im on the top floor, cant drop ANY weight, so gets tough when having to put down 100kg+ slowly![]()
From what I have heard you shouldn't try and do the negative part of deadlifts slowly, it's a vulnerable part of the lift at heavier weights
From what I recall....pretty much as you said. By all means get it down to the knees controlled, but after that, lower it with mavity basically
If the gym doesn't like it, ask them to get some extra padding for the deadlift area, or see if it can be moved to somewhere else I guess. Some gyms just don't like it, even though it's a popular lift and has been for decades.
No idea why people keep putting gyms upstairs mind![]()
I do mine at home, sorry, should have said![]()
Ah, bit annoying
Do you have a garage? Or a shed or something? Failing that just do them outside![]()
