Whats the best way to tell if its a 2b without taken thing apart?
The serial number on the outside of the box tells you what version it is![]()
thanks! They have 2b on the serials
What is the 100hz/60hz.. I have re-ordered a Pcbank super 27" will this be a 60hz ?? Will this be ok for general use and gaming. My current BenQ 22" is 60 hz but is a TN is it different for IPS panels.....
All I wan't is the same as what I have but bigger and better pic not worried about 3D or overclocking etc...
WOOHOO!!!!
DHL are simply awesome!
Wednesday night it's sat in the warehouse S. KOREA. Thursday it's managed to get to Germany, THIS MORNING MY HOUSE!
How come I can get a parcel from South Korea in less than three days where LG took over 14 days to get a pair of glasses from the UK ......to the UK LOL
No import charges so far
what ver did you order craarc? and what hz are u running at on which gpu?
ok, quickly set it up at lunch time
I ended up with the non glass model (which I wanted) and by the looks of the serial number it's a 2C (at least that's what's in the middle of the long number). Mine was ordered from bigcloth and decided to take a gamble on a catleap without the pixel check
Fired it up, WOW. It's HUGE! Quality is simply stunning, VERY rich and vibrant colours. Nice even uniformity across the entire panel. Bleed is ok I think, by that I mean that because it's so big if you sit dead centre the edges seem lighter, but when you move your head across to the edge so you're in the centre with the edge it's perfect black.
Unfortunately two little niggles
1. One dead pixel, off centre. Not really that bothered since I paid so little. It's lit green so anything black really shows it up. White background completly hides it
2. The monitor doesn't sit level with the stand, the right side is sitting lower than the left. Will have a look at the stand tonight but I think I'm going to have to wedge some cardboard under one side to level it up.
Perhaps this panel was rejected by a previous customer unhappy with the one dead pixel. I did wonder where they went, so perhaps it's factories like these who sell them on
HOWEVER......I only paid £215 all in lol RESULT! Well Happy
1) If the pixel is green then it is stuck, not dead. A dead pixel will be black. Try massaging it, they can often be brought back.
2) My stand isn't level either, I just rested one side on my keyboard cable. The keyboard cable goes to the back of the desk anyway so I just slid it under one side of the stand. Now it's perfectly level![]()
message sent![]()
I paid £180 for my Dell U2311h 6 months ago.
