!! ( I am still looking)
By the way the manual says sod all about disabled SATA with MSATA must be why we got the big stick lables over the ports!! ( I am still looking)
I'm using this with a Xonar DS card and a 5.1 AMP (DTS connect), would I be better using the on-board or should I stick with the Xonar DS?
It does, its on page 11
I got a Xonar D2 and I know that this M/B wont beat it , but for you it will be on par so you wont loose but you wont gain.
Personally I would stick with using your card and disable onboard! If you like your music you know separates are better!!!
Reason I purchased this board is because it had a PCI slot for my D2!![]()
Am looking all I got is for ports
Internal connectors
5 x SATA 6Gb/s connectors
4 x SATA 3Gb/s "
1 X mSATA
SATA 2 5 connector will be disabled if mSATA used!!! OK i get it!!!
But where the 5X 6Gb connectors come from are all the ports 6Gbs SATA 3?![]()
) it was looking at me !
now me thinks its them grey ports as i have seen on the net it works providing the HD drivers were compatible in some way !!!
o/jing!!
Only time though I think with out BSOD!!
I thought the headphone front 3.5mm socket had an amp x-fi aswell, Not just the back pannel, Or am i wrong again.![]()
