Just read about the difference of blue capacitors and purple - they ran out of blue caps so they changed the manufacturer and the new manufacturer has different colour caps. Same specs.Tried the newer >> Intel USB 3.0 Driver v1.0.4.225 *NEW* >> Click Here ? that's what I am using now.
I can only update my BIOS using the USB ports at the back, it doesn't matter which BIOS or driver I use.
Once the system boots into Windows 7 the front ports work on my 650D case, probally not an issue at all just the way the motherboard works, I'm going to e-mail Gigabyte about it all the same though.
there was a post here about not being to flash your bios via front usb
http://www.overclock.net/t/1239993/...rt-thread-and-club-ud5h-ud3h-d3h-and-all/1090
so GB has made it so that when users flash they should use the physical ports which GB knows are properly powered and correctly situated. That is why you need to flash from the back ports.
