- 30 Nov 2011
Its just normal, definitely quieter than the ref 6970 that it replaced and that wasn't overly loud either. If you were after silence then yes you may find it audible, but you shouldn't be buying reference cards either.
Forget about the 70c-80c thing, this card is tuned to hit 80c where it will lower the voltage slightly so the fan runs at a slightly slower RPM thus is quieter. The max overclock you want to look for is the one when its running at this state, so mine runs at 1190-1200mhz when looping Heaven at 80c. Whilst running BF3 with a slightly lower GPU usage and lower temps it runs at about 1220mhz. Any higher it will crash.
I only mentioned it because a certain someone on here was making a massive deal out of the 15mhz it costs you... to me 0.1 of an FPS doesn't matter if it means saving £50, particularly as I plan to SLI them sometime in the next few months
80C also doesn't bother me, my 580 phantom got up to 85 on full chat so I'm again wondering why all of a sudden 80C is a big issue for some people :/
