being lazy but can you save your current setup as last time i upped the bios i had to reset everything which was a pain
Yes.
At the bottom of the OC Tweaker menu there are 3 "slots" for you to save different profiles.
thanksSo question is should us who have sandy update?
only intel ME driver i've installed. most of that ^^ just to support IBhas anyone installed all the new intel stuff?
http://www.asrock.com/mb/download.asp?Model=Z68 Extreme4 Gen3&o=Win764
http://www.intel.com/en_US/Assets/PDF/general/tr_provisioning_montevina.pdfWhat does intel ME do? I never bothered to install it, after I did a fresh windows install.
yes it's not needed tbhThanks Ok so its seems to be network based therefore not needed by me.
yeah it always wipes it after flashing a biosby the way just flashed the bios and even though i saved my profile before it wipes it... so beware!
had to reset everything, hope its all good!
yeah that is correct and what i thought, but Surveyor a few posts up said it saves it - pffffff
i can't quite believe someone gave bad advise on the internet![]()
The bios looks nice. Improved gi and mouse moves better. Can't see any improvement that are noticale in performance
as anyone upgraded to 2.10 yet with a SB chip?
it says "After you finish updating this BIOS, please reboot your system. Please only flash newer versions of BIOS in the future."
so can't downgrade after?
...managed to overclock my SB I7 2600k to 4.5 (air).
Haven't you oced it before with old bios?
