Bump for those looking for this thread![]()
Cheers, was getting blurry eyed sifting through all those pages! Bookmarked
Also worth noting that (from a customer pov) the RMA is now dealt with by the retailer (even after 12 months) rather than with the RMA base in Netherlands as quoted above now.
Yeah given the choice I'd have preferred to cut out the middleman. Seems a bit weird that it would take longer for an indirect RMA; if anything you'd expect it to be quicker (ignoring the additional transit days) given that the item should in theory have already been tested by a reputable reseller (as opposed to just taking the customer's word for it). OcUK sent it to MSI on the 14th and received the replacement on the 6th which even if you take the bank holiday out of the equation was a 3 week turnaround.
it takes flipping ages to get the card replaced, i have to wait another week yet, they've had it a week already and they havent even looked at it yet !
oh well, i may as well replace the hard drive whilst i'm waiting
You killed it already?
Poor mal
Bet you're glad you didn't varnish it now!![]()
mine died two weeks ago, it only lasted 6 hours !
i'm not going above stock volts next time..... no way ! because i wasn't careful enough last time, i OC it way too far
yea can you imagine if i varnished it
i'm not going above stock volts next time..... no way ! because i wasn't careful enough last time, i OC it way too far, to be honest i dont think it needs much OCing anyway.
the card blew without crashing first, it OC fine; i never had any trouble with it on MSI Afterburner, i noticed no signs of trouble first, the only thing that i didn't like was the increase in Coil Whine.... it got very loud, i should have taken this as a warning sign....silly me !
so next time i will stay on stock volts and watch out for coil whine, because as soon as i start hearing it i'll back off straight away
so you mean if you kill a card by overclocking, you can RMA it?
Presuming you use software I overclock, then yes, you can.
The manufacturer has no way to prove it was overclocked unless you do something stupid ofcourse![]()
Such as admitting it on a very popular internet forum?![]()
