Updated to F8 this morning, reloaded defaults then changed the settings back to what I previously had which is:
CPU @ 4.00ghz, stock voltages, turbo off
BCLK @ 100.10
RAM @ 2133mhz and 1.45volts
Booted fine, used it for a few hours fine. Turned pc off.
Went to turn back on and got a boot failure...checked bios and my bclk was showing at 97 something? Not sure if that's just a failsafe setting to get you in the bios?
Anyway, switched bclk to 100.00 instead and it actually seems to be running at 100 now. Guess F8 fixes that issue
Will see if it happens again, interested to know if anyone else has a similar problem.
BCLK @ 100.10
