Am I crazy to be buying a 15" top spec normal MacBook pro?
Should I get the base retina?
Nice one Izi
I was tempted by the base retina, but need a big HDD.
Just curious do you know if the SSDs can be changed in the retina?
I can't help seeing the retina as just a giant MacBook Air. It's to all intents and purposes non-upgradeable once purchased which is borderline insane for an £1800 machine. All my previous Macs have had more RAM and a bigger HDD installed at some point.
I'm still glad I got a late-2011 when I could.
Likely. The MacBook Air has a blade-type fitted, it's likely to be similar in the R-MBP. That said Apple changed the proprietary connector again for the new machines. OWC in the US have an upgrade range for the old-blade type.
That really doesn't hold up. The i5 is virtually identical to the i7, it's just missing hyper threading (generally pointless) and a bit of L3 cache. Factor out the faster clock speeds and the difference is hardly measurable for the vast majority of tasks.
A more accurate example would be :
i5 at full power for 6.0 seconds = heat for longer
i7 at full power doing full job 5.8 seconds = less heat
Oh, and the standard warranty is 12 months unless you buy AppleCare
*apart from education customers.
a lot of benchmarks showing up that the i7 is miles ahead of the i5.
Source?
What happens to all the Apple Store demo units, the outgoing models? Are they available somewhere discounted?
Mac rumours forums has piles of links, talking some jumps of geekbench from 5XXX to 7XXX on the i7. No reports on battery life but people pretty shocked at how the maxed out 11inch is a power house.
How're you finding performance? Anandtech says that performance on the 4S seems to be better with Safari, but how are you finding it generally?
