- 14 Jun 2004
- Newcastle U/T
There you m8!
http://speedfan.en.softonic.com/?ab=6
Here is another link
http://majorgeeks.com/SpeedFan_d337.html
Was thinking more of an official GByte app but will have a looksee @SF
There you m8!
what ram would you recomend for this board with a 3770k in it??
:shame:Nope, mine freezes when just web browsing.
On a side note, back to 100.1 BCLK and no freezes since. Very strange.
i uninstalled USB 3 drivers - since then no problems at all (and i had latest USB 3 drivers)
before im getting 6-8 crashes/freezes every day
could be ram voltage or cpu/vtt voltage not right,what are you using atm?
did you manage to catch the bsod error codes? it will be 00000101 or 0000124
101 usually means not enough cpu voltage
124 means not enough dram or cpu/vtt voltage...can also be not enough cpu voltage on sb/ib
0xD1=QPI/VTT, increase/decrease as necessary,unstable RAM,raise RAM voltage.
I don't know.what they are that's why I left them alone Lol
What do i need to do and what are the safe limits?
Is it safe to go over 1.5v with RAM I read it can dmg the CPU?
you can use upto 1.5750v for dram,id run 1.55v,ive been running that and higher without any trouble
cpu vtt or qpi/vtt you can safely use upto 1.2v although you wont need anything like that amount,id try 1.10v from stock 1.05v and see how you get on
Hi,
This is related to the UD3H board but I thought you guys could probably help!
I received yesterday the GA-Z77X-UD3H and set it up to test (outside of case).
It will boot up ok initially and I will get a brief view of the Gigabyte splash screen and then the screen will go blank. It does not matter which connection I use this always happens. Everything is still running but the screen is blank. I have used both onboard outputs and the graphics card output but to no avail.
I have tried without the graphics card plugged in but the same thing happens.
The USB keyboard and mouse are lit up and all fans are going but no display after the brief view of the splash screen. Is the motherboard faulty? Or am I just missing something?!
Thank you in advance.
Looking at the codes that come up as it start up it goes through a different numbers. Get to 99 (super IO initialization), then A3 (Acitivated all currently connected IDE devices; that is when splash screen comes up), quickly jumps to A9 (BIOS setup started; splash screen disappears) and then settles on A6 (Detect and install all currently connected SCSI devices).
