Might do that and use my 7800n in that case
Thanks
Apparently you can get some beta firmware for the 7800n if you want to use it as a replacement for the sky router.
Thanks
If you intend to do some P2P downloads, stay away from BT Infinity (unless you intend to get a VPN, which is going to cost an extra £6/month).
I you are not going to be using P2P, then go with BT.
Fibre was enabled on my cab today - think i will move over to sky fibre..
I have received a discount in the post today giving free installation for SFU.
Quidco are also doing £95 cashback too (online only), BT has no cashback option. I am currently with BT for my line rental and O2 for my broadband.
Is the ordering process online for fibre straightforward? I will also need a data extension kit fitted - can this be organised online?
not everyone is throttled on p2p as i haven,t noticed any change in downloading with p2p but also a Newsgroup is another option to use![]()
Just a sky tv subscriber, must be about 15 years or so now. We used to have sky broadband up until 5rs ago or so
I had originally signed up for updates to sky fibre when it was first announced - that could be why I received the offer.
I can also see the offer when I sign into the mysky portal on the website - have a look there for it? The offer has only come up since my cab was enabled today - has your cab been enabled ?
You're right. Some people on BT Infinity are not being throttled on P2P. However, there is no guarantee that you won't be.
Sky DO guarantee no throttling.
Newsgroups: you are looking at paying £5 - £10 per month, so you have to factor this into your monthly cost.
its kind of where you live and what volume of B.T Infinity is on your exchange ,i,m lucky that most people around me are all on Virgin Cable or Sky T.V deals so i am probably the only one on Infinity in my road and for p2p thats good
I've just ordered the Sky FTTC Unlimited, and I'm thinking of ripping out the old BT socket and whatever wiring going to it as I can, I'm correct in thinking they will run a new line in when they come to install it right?
No. Leave the socket alone.
