First match on google.
Didn't have anything else handy that I could wipe.
Thanks.
All installed now. Not that impressed to be honest (Although I guess I have ben using SL for 3 years).
Bootup and shutdown (which to be fair I rarely do) are both much slower. On SL the spinning thing during boot would spin 2.5 times. Now it is 9. On shutdown I would never even see it, now I do.
New gestures are all a bit rubbish and I find fullscreen mode a bit confusing as well. I will have to install the tool someone mentioned earlier to reconfigure the gestures.
iCloud integration seems good, Mainly the seamless sync of Notes to my iPad will be handy.
if I had a copy of the SL DVD (I gave mine away!!) I would just reinstall that back tbh.
rp2000
i didn't realise they ditched front row? i never had lion so...
my menu button on my remote is pointless now![]()
Yes, it was gone in Lion as well. I honestly can't remember much of Snow Leopard. Not sure if it was still there. As I wiped that image the other day.
Apple seems so good at that. Bring in things, has a short run then ditch them. :/
You can use BetterTouchTool to customise the gestures to your preferences. I can't remember what is default anymore as I have my own setup. It even let's you setup different gestures for different apps.
Anyone got any tips for good swipe gestures?
rp2000
Can't say I have noticed any difference.
I've got a three finger swipe up/down that takes me to the top or bottom of a page. Its very useful when browsing/viewing large documents.
It's a font smoothing problem, disable it in System Preferences > General or open Terminal and play with "defaults -currentHost read -globalDomain AppleFontSmoothing -int X" where X = 0-3 for None/Light/Medium/Strong. "killall Finder" and quit your browser or logoff/in after performing the command or changing the setting.
