I guess that just proves my point.
Only as far as colour reproduction is concerned. Nothing to do with the bold as my screenshots are from the same monitor and same settings only difference is one is running Lion and the other ML.
I am. Reading this thread at the moment on my iPhone 4S and the top JPG is still a little too faint for my liking. The boldness, especially on these forums, helps the text stand out from the background and requires less focus to read.
Why is the text bluey white though? the text should be pure white. (...) I guess that just proves my point.
V F said:Though, you're the first person I've seen in recent years thats complained about font rendering. Most that came from Windows preferred the thicker look because it was easier to read than the thinner cleartype look.
Filed report. This is worth exploring though, I think I'll try and see what larger mac forum thinks about it. I think it's just a case of detail blindness - as in - some people didn't notice font being different and just don't care, but will argue anyway, but if it turns out to be device specific bug and mac users are in two camps - one looking at bolder fonts and other looking at smoothed fonts for years, it'd be comedy gold.v0n, stop complaining on a forum and file a bug report?
I think your colour calibration is messed up. It looks fine and white on my dell 2411, 2007 macbook pro and mac mini hooked up to generic AG Neovo LCD.
Leaving aside that you are replying to multiple people complaining about font rendering - you've just been shown by Skyboat via screenshots that Lion indeed used regular weight fonts. I'm looking at Macbook running Snow Leopard and the font is also regular, not the thicker size.
I've never encountered this "preferring the thicker look" thing. As you can see it never happened to some of us. If it's normal for you it almost certainly must be some device specific anomaly - I'm thinking maybe devices with smaller screens ended up running some sort of "accessibility" thing on fonts or something (then again my MBP never had it, and it was stock Apple installation).
Mine is messed up? seriously... yours is only one that shows up bluey white.
Mine isn't like that, my text is perfect.
Which way perfect?
is it worth the upgrade for this
MacBookPro7, Intel Core 2 Duo, 2.4 GHz, 4 GB RAM Still running Snow Leopard.
Is there a way to change some of the system gestures? I always used three finger tap to act as middle click for opening tabs easily but now the dictionary definition has taken that role. Currently I'm using a four finger tap but it's not as nice![]()
Download BetterTouchTool so you can customise gestures on a global or per app basis.
