It was released to developers on July 10th - so no one is impressed by you having it a week ago and then writing off any changes as 'Hype'; it just makes you look foolish.
FWIW - a proper review is here
He's a known troll. Don't humour it.
I had this as well, its a problem with Apple's Disk Utility, not the image you downloaded etc. Use any other image burning program and it works fine.
Aye, so long as you eject the disk properly it should work just fine (mine have every time).
I agree with v0n above on his "notifications" bug ... not getting any Twitter messages on mine even though I've given it my account and just have a click to tweet thing there.
I used to get that in Snow Leopard but it's never happened in Lion or ML. A reboot was the only fix for me.Wow this release is buggy. Spotlight just packed up all of a sudden. Worked all day, then just didn't. Finds stuff manually in Finder, but not from the top bar, only shows dictionary suggestions and web search. None of the usual tricks work, adding and removing main drive in privacy settings, mdutil -i on /, mdutil -E /, removing /.Spotlight-V100. Nothing, no indexing dot in top bar, no search results. Only in Finder.
I just tried to install libdvdcss.pkg and couldn't because of the app store and only identified developers being allowed on the platform. No problem say I, I will extract the required file and manually move it to the directory it is required to be in. Done. Now let's see if I can do what I want to do. NOPE. Action not permitted. **** off.
Disable Gatekeeper or right-click "Open"?
