Anyone else have their quidco not track?
Mines over 3 days now and I'll need to raise a claim, great!![]()
All good - any good guides on unlocking modem to find max attainable speed? Is it wise to do it now or shall i wait until after the first 10 days
Huawei or ECI?
can one keep bt line rental and still op for sky fiber ?
so if I switch to Sky now, do they get access to provide fibre broadband from my newly enabled cabinet at the same time as BT would in November?
Huawei or ECI?
Unlikely. I would hold off for a while. Sky have to upgrade their kit at the exchange.
Doofer
No settling in period with FTTC (mentioned in here and also here.
Sounds like you have a carp line there. There may be a dodgy joint or termination somewhere along there. What results do you get from running a quiet line test?
I did eventually get through and it said there was echo and noise on the line and then it cut out again, it's hammering down with rain and the line has always been at it's worst in these conditions, I'll try phoning Sky later and report the fault though I don't hold out much hope as BT never fixed it and this was the main reason I switched to Sky to begin with...
