Post your mobile phone desktop!
I just updated 63 apps.................. :D :D :D
Maybe i should stop believing 'if it aint broke don't fix it' :p
Having a bit of a woman free homescreen for a while...
To be fair most of them were things i never use.. Although i was a few dropbox updates behind and guess what now it works perfectly when before i was having some troubles with it taking a while to sync to PC :rolleyes: :p
Height and width margin? E: Oh i see yeah it is a bit low :p Oh well.
Why would you not update your apps? I'm like an app update addict! If I open 'my apps' and see 8 apps need updating, it's like Christmas morning!
There's been a few time where an update has changed things I liked about the app - for example the exdialer ICS skin update which took the gradient off the background and replaced it with black. I only update if I need to - on my most used apps that is. I'm just lazy on the other apps as I hardly use them.
Same..... :o
Each update has usually always improved current things by quite a bit or added new things, never had any problems and if there is a problem, which most people are experiencing then the developer is very quick to get a fix released on the same day.
Although as kona pointed out, if an app requires new permissions, which there is no need for or completely gets ruined with stupid pay to use services i.e. zombie booth then I won't update :p
Nope! I have Large hands and only a 4.2" Screen... just took about a day or so to get used to it being up there!... :)
Getting bored of the black background now, have had it for far too long! :p
Rather liking this at the minute, just using the sense wallpaper for the matte theme:
Again, looks much much better on my mobile screen, not sure why but photoshop seems to reduce the colour quality and sharpness.......
Have a whole black background wallpaper set similar to the above, but think that one looks the best.
Going to maybe get rid of one of the minimalistic text widgets and perhaps move switchpro onto the main screen.
