Borderlands 2 release date confirmed ( Launch trailer also )
There probably isn't. But that means you can't talk to anyone on Steam, nor can you play co-op with anyone.
Waiting till I get home from work on Friday and spending as much of the weekend as possible playing it seems to the better option.
Aye i see the point, hence why i havent done it so far hehe, just bad timing for me as ive got my son all weekend so my playtime will be next to none haha.
Well, I have just purchased for PC.
Absolutely buzzing for this now!
Have added most people with Steam names in the thread. look forward to playing with you guys on friday!
Anyone thinking about using a vpn ? I used one a few weeks ago for sleeping dogs. Unlocked on 12 on Monday night and played in offline mode till Friday. Not a problem.
Im going to save my excitement for the weekend I reckon. Friday night, beers, snacks and Borderlands. Epic.
Unlocked it using spotflux, played single player for a bit since couldnt get coop working, utterly fantastic game so far though. Probably going to leave it until friday now / until i can get coop working.
One issue i had with spotflux was that it messed up chrome so that i couldn't browse anything unless i was connected to spotflux :s , took me utterly ages to fix which was annoying now have it uninstalled.
I can also confirm that you can use Spotflux to get it working, albeit single player only. The game re-locks once you turn the VPN off but it's no hassle to simply unlock it again. I also didn't have any problems with regards to Chrome.
A few (rather boring) screenies. but at 6000x1200
58D774D19680BEB42F2007846E97542CF50CCA0D
C95BE5E7B8176457A818CD966D9415DB54A60452
:D
Ok so iv been trying to figure out how to enable Physix since I dont have an NVIDIA card. And I managed to find a very simple work around (Off the net)
Here it is.
And it works! AMAZING difference.
C:\Users\USERNAME\Documents\My Games\Borderlands 2\WillowGame\Config\WillowEngine.ini
Search for:
PhysXLevel
Change
PhysXLevel=0 <- (low)
to either:
PhysXLevel=1 <- (mid)
or
PhysXLevel=2 <- (high)
I created a new thread just for this. Delete my other tread if you deem necessary. I just wanted it to be easy to find.
Thanks! LOVING the changes! CRAZY!
if anyone wants to group up for some coop, add me on steam: Semiskimmed :D
Coop doesnt work i dont think unless you run it through the vpn.
*edit thinking about it you could maybe vpn + hamatchi start a lan game then close vpn, would that work?
Has anyone whos unlocked early got coop working?
This sucks!
Trying to contact getgamesgo customer support and all I get is
"There was a problem sending this form. Please try again now or in few minutes time."
I've tried umpteen bloody times :mad:
Here it is.
Search for:
PhysXLevel
Change
to either:
or
You can change that in the graphic settings, you don't need to do it in the .ini file
