rjkoneill Get your act together!
EP3 Premier Seats going cheap in Telford up on the Civic Type R Forum. Get them bought! He wants £350, and your stock seats!! Clicky Click Click
Members only
Members only![]()
Tegwa provides great 'bang for buck', Toda is the best but you pay a premium for the quality.
I have the TDI manifold (XO/AAS) and this is a dyno comparison against, Toda, mine has better top end due to the long primaries but loses quite a bit of midrange torque which is what most FN2 owners want to improve the most.
I don't know the in's and outs of an S2000 though.
tempted to split with someone else, I need a passenger seat that's easy to get in/out of as I CBA to face the cost of fixing the bolster soon![]()
lol, it's for the passengers side
I don't drive fast when there's a passenger so it's wasted! Looks a bit ***** though![]()
Its not obvious at all, infact the original statement was tongue in cheek so Im not sure why you are taking it seriously - in any case if we were to take it seriously.
The two best headers for the S2000 are Js racing and Toda. Both use different size primarys and secondarys yet are both very good, all the 'copies' seem to be no where near.
Also the pipe diameter is often quoted as OD yet the TODA uses really thin wall pipes. A lot of the copies use thicker walls which has a habit of being too strong in the wrong places (around brackets subject to vibration) ended up with a manifold that cracks/splits. Not easy to repair without having the backside of welds causing flow issues.
Last point on this, the standard S2000 manifold is very good. A nice looking copy will often perform worse, spoon is an example as these lose top end power with a tiny midrange.
So £450 for a copy to maybe lose power or similar cost for a proven part. Anyway I believe they are running a members car on Monday for before and after (Manifold the only mod)
Alright put your knickers back on.
I don't recall taking them off
