*** The 2012 Gym Rats Thread ***
Status
Not open for further replies.
A guy I'm coaching is stubbornly sticking to DOH, but still managed a PB of 180kg (+15kg) on wednesday :confused: I think his mixed grip PB is 140kg.
That's odd, but fair play for sticking too it, it is far more rewarding I guess. Progress just can be made a lot quicker by switching to mixed grip
I just switch to mixed when I give in to my girlyness. However, continuing on DOH is worthy of praise... but if he starts to stall he'll have to accept to either use hook grip or mix.
Delvis - if you ever move to mixed grip remember to keep the arm straight, don't bend at the elbow of the reversed hand as you will be increasing the risk of tearing your bicep. Yes, really :)
Yeah, some horrific one occur quite often.
Tbh I'm going to start doing direct bicep work again to help protect mine when doing deads and tyre flips (notorious for tearing biceps).
Because it's been discussed many times around here before and is hardly an advanced technique. And I won't believe the "I must've missed it then" line from someone with nearly two thousand posts in this thread :p
Shoulders tonight, should hopefully blitz the current weight I've been working on, which means moving up next week \o/
I'd stick with DOH if that's what you've always done
Man points for deadlifting a PB with DOH far exceed those of a mixed grip lift, that said, my grips just not up to doing DOH when it gets past around 140kg,
Aye I'm intending to matey, atleast until I literally cannot hold the weight.
Ugh, seen some videos of that, not nice at all!
Post count is meaningless, it doesn't mean I've read every post ;)
I refuse to believe you couldn't work out the relative likelihood between a bar rolling out of someone's hands because of DOH grip, or rolling across a flat surface because of DOH grip. :p
Well, I did wonder, hence the question. I'd have just said 'lost my grip' as opposed to 'letting the bar roll'.
Anyway, deadlifts tonight, should be a PB for reps over my 1rm.
Delvis the problem is you just don't seem to think before you post sometimes. I mean come on how is the bar supposed to roll away from you if you DL on a flat surface :confused:
People aren't hating on you, they are just loling at some of the stuff you say. We do the same to everyone who makes dumb posts, you just happen to do it more often than others ;)
No, no, next time I shall assume the context of previous conversation is lost and post adequate details as to not derail the thread with misunderstandings :)
What I originally meant to post was:
I can D(ouble)O(ver)H(and) the 125kg [weighted barbell], but it [the barbell] rolls out [of my hands] after a couple of rep(etition)s.
True, and I admit that :o...And to be fair, when you've deadlifted with hex plates you'll know for a fact they roll away ;) Bloody things!
I blame my parents personally.
Much better :D
Squats:
60x5
100x5
130x2
150x1 (did it beltless so technically a PB)
162.5x3x2 (PB)
Bench:
60x5
70x3
80x2
90x1x2
100x1
Pushdowns:
80x5
100x1x2
Squats were easy. First set felt and looked high on video, so buried the second set. Bench was an absolute grind for 100. Did 90 twice because first time was really hard, but had a bad hand off so tried again and it was fine.
Vid later.
Status
