hi Richdog did you get one yourself ?
Kenneth
I am typing this reply using a ug802 which is one of the newer android mini pcs. It has the RK3066 chipset which has a dual core cpu which scales fom 1.2ghz to 1.6ghz. The Antutu benchmark is the same as a Samsung Galaxy S2. There are reports of Wifi issues but I have done the "fix" of running the wifi antenna through the case so it's external and I am now getting 18 to 20 MBits near the router which is the same as my Galaxy S3.
I am extremely pleased with mine, there are audio sync issues on videos but this will be fixed by a custom rom.
Tried running a xbox controller to play some games but it didnt work, again will be fixed by a custom rom. Tried Shadowgun and it looked more than decent.
The ug is just a rename off mk they have the same chip.
Do you have a photos off the aerial mod you made ?
Kenneth.
placed order on 28 september, had to follow up week later ie 8th october, still have not recieved item.
kenneth.
to date 10 days, although it stated 15-30 business days, have to wait a bit more.
Zero point getting the mk808 it is pretty leggy, just got the ug up and running and it's pretty smooth. Haven't tried it out fully yet.Does XBMC run well on Android, or rather will it run well on the MK808? This thing looks fascinating!!
these are getting improvements so far, dual core seems good enough. Now I've tested it out on bedroom tv. Think ill get the quad core for the lounge.Been using the ug802 for a few days now and it's night and day better than the mk802 there is next to no lag and works like a dream for streaming netflix (apart from wifi issue, but can either mod or just use a USB to network adapter). I don't like the media interface on it though, wish they had just stuck to vanilla android. But as we all know you can find roms if you so wish.
Excellent - I will buy this now. ROMs easy to flash/bootloader unlocked? Doesn't the MK have a Mali GPU? How does the Vivante GC2000 GPU fair?
