But most of those aren't really an issue for most people. The CPU/ram, unless you're using games Iddon'tsee an issue
And the Iphone crowd would buy a poo if it had iphone 6 on it (some of tgem)
Its just not worth the extra hundreds.
For me it needs
Bigger battery
Bigger storage
Different look
I can see what you mean, but if all those areas that I have listed are indeed much improved over the GN, then it really is worth upgrading from the GN to it. It might not sound like much improvement in real world usage as the GN with JB is very good, but you do notice it in day to day usage i.e. all the people that upgraded from the GS 2 to the GS 3 have said that after having used the GS 3 for a few weeks, they have noticed just how much better it is due to the minor improvements in things like audio, battery, camera etc. and the GS 2 is better than the GN in pretty much every way except the display and stock android and for some, looks/build.
I personally notice a difference when I compare my one S (S4) to the quad exynos GS 3 in terms of snappiness/instant feel i.e. loading apps, loading game levels, loading the gallery etc.
You're right about the 2GB RAM, not an issue for a lot of people, but as shown in the videos posted by kona, it makes multi-tasking much better, you can do so much without apps closing and the tabs in the browser reloading when you switch back to it.
True about the iphone owners
As I said, battery life in theory should be very good, as the one XL (S4 dual with a 1800mAh and 4.7" 720 IPS display has the best battery life [excluding the note II, RAZR HD etc.], better than the GS 3)
Here are some reviews of the LG optimus G, pretty much the same as the LG nexus 4 specs, although we can't really judge battery and the camera (but it looks very promising in the below reviews), as the software/drivers plays a very big part in those areas:
http://www.slashgear.com/att-lg-optimus-g-review-16252010/
http://www.ubergizmo.com/2012/10/lg-optimus-g-review/
The display looks and sounds epic, can't wait to see how it compares to the likes of the note II, one X, GS 3 and iphone 5. Everything else sounds very good as well.
TBH, I rather they kept the design/look for the LG nexus 4 the same as the optimus G, might not be as comfy to hold but it looks so much better!
EDIT:
Essentially the main areas that people hate about the GN have been improved:
- audio
- camera
- hardware (a lot of people didn't buy the GN due to the hardware being worse than the GS 2)
Please tell me that the successor to the GS3 will have them?
