Z68 Extreme4 Gen3
im screwed with 16gb of memory, as mentioned before, even if i turn off my overclock and set memory to auto i get a bluescreen and crashes with another 8gb of memory. mem test says all are well
SB doesn't like memory with voltage more than 1.5v, from what I have read 1.5v is memoty sweet spot for SB. You should try different memory with 1.5v. I use these http://www.overclockers.co.uk/showproduct.php?prodid=MY-143-CR, and can overclock to 5.2, but settled at 4.8 for a quiet life with no problems.
AsRock Z68 Ex4 G3, [email protected], Ballistic Tracers 16GB,
5850 1GB(CFX), CM90 II Advanced, Crucial M4 256GB, 4 HDDs,
NH-D14, XFX 850W BE, Xonar Essence STX, BlackGold HD DVB.
tuned out i had a dodgy memory stick.
anyway reinstalled.. i seem to have a minimal amount of drivers, mainly intel... anything missing i need?
Hello
Has anyone experienced random (cpu wasn't loaded at the time) 'memory management' BSOD's (2 so far in the past 2 weeks) with this board, if so how did you fix it without RMAing the ram?
Really a pain in the butt :mad:, as my once stable 4.3oc since oct'11 is now slightly unstable, memtesting the ram (using the xmp profile btw) with my overclock results in errors really small ones like 2-3 in a single pass and at most 200 or so errors. Having tested yeasterday i know the problem ram module but with my system at stock settings the ram doesn't show errors after 3 passes / 3-4hrs testing.
I'm asking as I've got a RMA number from g-skill but when they come test my memory in their test rig it'll probably pass memtest86+ or whatever they use.
Beginning to think its temp related, as any increase in volts to ram or cpu results in errors in memtest, gonna try downclocking the ram later to 1333 and test it with my overclock and see how that goes.
Thanks in advance.
Bad ram is bad ram, after trying to downclock the ram and my OC it still error'd. So on Saturday 4th Aug I rma'd the ram, my main concern was the length of turnaround but I was pleasantly surprised received my replacement ram on Thursday 9th morning :D.
All tested and everything is good again, got my stable system back. So *thumbs up* to g-skill for the speed of service.
hate this motherboard, it is horrible , errors! overclocking and booting errors everywhere! cold boot errors! awake from sleep errors! usb 3.0 keeps failing! a chip burned out on its own! i could go on!
Avoid it at all costs!
I'm being deadly serious. It is a pain in the arse. Google it, there are errors! ERRORS EVERYWHERE!!!
*ahem* did i get my point accross?
most likely u just had/got a fault board. 99% of people are happy with it, including me. i have no issues with this board..
also your blaming the board but it "could" of been another hardware at fault such as PSU
Can anyone post all the settings for I5 2500K and Z68E4GEN3 ?
And also pretty please, updates files to install drivers/bios etc? What versions you suggest, etc....pretty please, thanks
My components are:
I5 2500K
SAMSUNG DDR3 GREEN 30nm 2x8GB
TRANQUILLO GELID 2
INTEL SSD 320 120GB
CORSAIR TX650M
MSI N460GTX HAWK
ASROCK Z68 EXTREME4 GEN3
the windows7 ones should work.
but dunno why anyone would stick windows8 on any desktop pc
I just did it.
Day One: Hated it.
Day Two: Hmmm not as bad as people say.
Day Three: I won't be going back to Windows 7. I know, I cannot believe it, I am warming to Metro, even though XLan and XUSB do not work in Windows 8.
AsRock Z68 Ex4 G3, [email protected], Ballistic Tracers/RipsawsX 16GB,
well good luck mate, not my cup of tea, but installed on my laptop to make sure i can use and support it. works ok on that, and i appreciated some of the speed bumps.
just fired today for first time...out of box it was uefi 1.0....installed 2.30, all good so far....but damn bios settings, there's too many....where to start? all stock so far :P
i have gathered this drivers & utilites, anyone can correct me what is needed, what is not and what's doubled or anything, thanks:
ASMedia USB 3.0 v1.14.8.0 [Extreme7 Gen3]\
Broadcom BCM57781 v15.2.0.4B\
Etron EJ168A USB 3.0 v1.113 [Extreme4 Gen3]\
etron_115\
INF(9.2.0.1021)\
Intel HD Graphics v8.15.10.2761\
Intel Management Engine v8.0.13.1502\
Intel Management Engine v8.0.2.1410_1.5M\
Intel PCH v9.3.0.1019\
Intel RST v11.2.0.1006\
LAN(v14.6.4.2)\
Marvell 88SE9120 v1.2.0.1020\
Marvell_SATA3_Win7-64_Win7_Vista64_Vista 1.2.0.1003\
Nuvoton(20110219_CIR)\
RapidStorage(v10.8.0.1003)\
Realtek HD Audio R2.70\
THX TruStudio(1.00.01)\
VGA_Win7-64_Vista64(v15.26.1.64.2618)\
XFastUSB(3.02.30)\
ASR3TB+Unlocker_v1.0.exe
AsrAppChargerSetup_v1.0.4.exe
AsrInstantBoot_v126.exe
AsrRS(v1.0.6).exe
AXTUSetup(v0.1.220).exe
cfosspeed-v661-build1880-asrock-whql.exe
intel_rst_11.6.0.1030.exe
Lucidlogix VIRTU Setup_64Bit_1.2.112.20176.exe
Lucidlogix VIRTU x64 v1.2.114.exe
SETUP_0.115.zip
SETUP_0.115.zip.part
XFastRAM(v2.0.24).exe
XFastRAM(v2.0.9.2).exe
z68e4g32.30mod.zip
please share your installed drivers&utilites for this mobo.
