im screwed with 16gb of memory, as mentioned before, even if i turn off my overclock and set memory to auto i get a bluescreen and crashes with another 8gb of memory. mem test says all are well
Hello
Has anyone experienced random (cpu wasn't loaded at the time) 'memory management' BSOD's (2 so far in the past 2 weeks) with this board, if so how did you fix it without RMAing the ram?
Really a pain in the butt, as my once stable 4.3oc since oct'11 is now slightly unstable, memtesting the ram (using the xmp profile btw) with my overclock results in errors really small ones like 2-3 in a single pass and at most 200 or so errors. Having tested yeasterday i know the problem ram module but with my system at stock settings the ram doesn't show errors after 3 passes / 3-4hrs testing.
I'm asking as I've got a RMA number from g-skill but when they come test my memory in their test rig it'll probably pass memtest86+ or whatever they use.
Beginning to think its temp related, as any increase in volts to ram or cpu results in errors in memtest, gonna try downclocking the ram later to 1333 and test it with my overclock and see how that goes.
Thanks in advance.
.most likely u just had/got a fault board. 99% of people are happy with it, including me. i have no issues with this board..hate this motherboard, it is horrible , errors! overclocking and booting errors everywhere! cold boot errors! awake from sleep errors! usb 3.0 keeps failing! a chip burned out on its own! i could go on!
Avoid it at all costs!
I'm being deadly serious. It is a pain in the arse. Google it, there are errors! ERRORS EVERYWHERE!!!
*ahem* did i get my point accross?
New Bios out guys 2.30fw
Improve discrete VGA card vBIOS compatibility.
http://www.asrock.com/mb/overview.asp?cat=Download&os=BIOS&Model=Z68 Extreme4 Gen3
i wish i knew what either of those things meant!
Bios 2.20 also offered Improve discrete VGA card vBIOS compatibility, look at those release notes,might tell you more?
What drivers should i use for this mobo with Windows 8? There are none on the asrock website. Or do I just use Win 7 drivers?
the windows7 ones should work.
but dunno why anyone would stick windows8 on any desktop pc
